Access cRIO via VM
Hi Simon,
I was referring to the VM's network configuration - not the network configuration on the OS of the VM, but the configuration of the VM itself through the VM software you're using. (In VMWare, VM>Settings>Network Adapter)
I don't know exactly what the settings should be (as I mentioned, I couldn't ever find a setting that seemed to work reliably across all the VMs I was using, while also allowing internet access), but seeing those settings might give a clue to someone else.
Message 11 of 12
(514 Views)
OK, i will try to put here the settings that i can:
Description: Nutanix VirtlO Ethernet Adapter
Physical Address: 00-50-56-95-7D-41
Active DHCP: No
IPv4: 10.XXX.X.99
Subnet Mask: 255.XXX.XXX.XXX
Gateway IPv4:10.XXX.X.126
DNS Server IPv4: 10.XXX.X.90
                             10.XXX.X.200
WINS IPv4 Server
NetBIOS for TCP/IP: Yes
The VM is not connected to internet because reasons of security for our network.
André Simões
Work with LV2019 and cRIO since 2021
Message 12 of 12
(510 Views)
