Access a Eurotherm 2416 via Labview
Hi I am currently trying to access an Eurotherm 2416 PID controller via labview to make the ineraction with it easier. I connected the device with an RS232 cable to my pc and I can access it via Eurotherm iTools.
I also downloaded the et24xx driver from the NI website. NI Max is able to detect the device and I can also operate a VISA write function. But when I try to do a read command there is an timeout error. (Hex 0xBFFF0015) The same error occurs when I try to start the initialize VI from the et24xx driver. I did not modify the driver, which is attached to this message. I am using the LabView 2018 version.
Has anybody expierienced something like that and is able to help me? I am new to programming with labview, so if you need further information to answer the question you can also suggst that.
Best Regards, Karl
(1,255 Views)
Hello  ka.hero.,
I'm sending you two links that might help you to solve the issue.
Error -1073807339 VISA Timeout Error When Trying to Communicate to ADAM I/O Modules - National Instr...
VISA Error -1073807339 (0xbfff0015) Timeout Expired Before Operation Completed - National Instrument...
I think the second link will be especially helpful for you.
Best Regards
(1,212 Views)
