Access Pulse setting cluster
Could you help me how I can access to look at the logic connection for the 'pulse setting' cluster? (plz see the attached VI)
1. Duty cycle
works fine with "INT" trigger, but not with "EXT" trigger (sets the duty cycle value w.r.t. 33MHz always..try to modify to work w.r.t. ext freq input.)
2. Delay/Phase
Suppose to track each other...but can only do that with 'phase' value change...how can I do it either ways??
thanx,
Message 1 of 1
(2,542 Views)
