Access LabVIEW Property Node from VB
I'm using LabVIEW as an ActiveX server. I'm trying to access the property node of a multicolumn listbox from VB. Is this possible?
Charles Chickering
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(3,125 Views)
You can view the exposes methods and properties of LabVIEW by doing the following:
1.  Go to LabVIEW help at Program Files>>National Instruments>>LabVIEW 8.0>>LabVIEW Help
2.  Click on the Content tab at the top right.
3.  In the directory tree, go to Property and Method Reference>>VI Server to see the exposed properties and methods.
MulticolumnListbox Properties is located at:
Generic>>GObject>>Control
(3,090 Views)
Thank you for your reply, according to what I see there, under Help, Property and Method Reference, VI Server, Generic, GObject, Control, Properties, MulticolumnListbox, Item Names is listed as available. How do I access that property from VB?
Charles
Charles Chickering
(3,089 Views)
After looking at this some more, it does not appear to be possible because the VI>>Front panel property is not exposed in ActiveX Control Library 8.2.  I don't see any documentation explaining why this isn't exposed.  I will file this issue internally.
Trey B
Applications Engineering
(3,067 Views)
