Access DataSocket Server from MATLAB / C program
I would like to read (and eventually write) data from a DataSocket Server using MATLAB.
Currently, I am just using low-level UDP commands to send data from LabVIEW to MATLAB, which works but is somewhat cumbersome and prone to programming errors. Using NI's DataSocket appears to be a much more elegant solution.
Has anybody written code to connect to DataSocket servers using MATLAB, C or C++? Is the DataSocket protocol specified somewhere?
(4,876 Views)
You will find some examples in the LabVIEW example finder that I think will help you.  You can go to Help >> Find Examples... and search for DS Write.vi to find this file.  There are other examples if you search DataSocket.
These other links may help you:
DataSocket Transfer Protocol (dstp) Overview
Protocols for DataSocket and DataSocket Server
Message Edited by Brian R on 09-04-2007 09:33 AM
Message Edited by Brian R on 09-04-2007 09:34 AM
(4,846 Views)
Dear Brian,
thank you for your help. I have succeeded in posting data to a DataSocket server from LabVIEW, and I can read it from another LabVIEW program. Now, I would like to access this data from other programs than LabView. Is there some C / C++ / MATLAB example code on how to do this?
Thank you
Rasmus
(4,837 Views)
Have you look at measurement studio ? I think they expose access to read Datasocket or variable from c side.
(4,833 Views)
The following article shows how to do this in Measurement Studio.  [link removed; article no longer available]
Thanks!
(4,823 Views)
