Acceleration to displacement problems
Anyone got any idea why my displacement graphs are telling me there is a maximum displacement in the tens of meters? The sample was securely fixed and would not have moved anywhere near a metre.
Message 11 of 14
(746 Views)
Hello again,
My overall objective is to produce a logical displacement curve from the acceleration data attached. Previously there was a lot of noise and useless data which I think was leading to weird and non-sensical displacement and velocity graphs. I have now tried to cut down the data to the main impact event in excel. I now want to reimport the excel data and produce the displacement data.
I've tried to make a start at the importing of the excel sheet using the read delimited spreadsheet Vi, but I'm a total beginner and don't know where to go from there.
If anyone can help, thank you!
Message 12 of 14
(775 Views)
Hard words: garbage in -> garbage out
the measured acceleration is mainly positive -> integral (velocity) mainly increases-> integral (displacement) increases
see post from GerdW.
Even a sligth bias removement  (usually done with a highpass filter) wouldn't help.
In your first post you posted the expected wfrms. The point of investigation would have been while monitoring the test and not getting the expected results....
A possible (not so rare) source of error could be  loose contacts at the accelerometer connector .. this results in short positive peaks ( positive slew rate is a function of supply current (4mA) and cable capacity, neg. slewrate much faster) ... If this happens at negative accelerations (also plausible)  you could end up with such signals.  Since the open cable detection works by detecting the crossing of a voltage in the 19V to 22V region and your loose contacts are short, this only can be seen in the signal... but would have needed a higher samplerate or a scope ...
Greetings from Germany
Henrik
LV since v3.1
Message 13 of 14
(733 Views)
Did you even try to run your code?  I ran only the Read Delimited Spreadsheet part, it asked me for a file, I gave it the downloaded "integration test.txt" file you posted (thank you), and got this:
Isn't this what you want?  I assume you know how to use LabVIEW's Help feature to learn about the Delimited Spreadsheet functions, and to know you can also wire a path to the input if you don't want it to ask you "What do you want to read?".
Message 14 of 14
(730 Views)
