Acceleration and Frequency range for Accelerometer
Hello All
The phonomena that I want to measure the vibration for has the following expected charectaristics:
Maximum Expected acceleration =  1.5 g
The frequency range could be less that 0.1 Hz
Now I want to decide the right IEPE accelerometer for this measurement with high accuracy. With what acceleration range and frequency range should I choose my accelerometer???
Thank you
Message 1 of 8
(4,265 Views)
The low frequency range make it challenging 😉
What type of signal conditioning do you plan to use?
A lot of IEPE conditioner have high pass characteristic with a 3dB cut in the 0.1 Hz range, just like most of the IEPE accelerometers.
Resolution and upper frequency limit ?
Other environmental needs?  (How do you want to mount the sensor?, temperature range? )
Really cheap sensors are MEMS based, have +-2g and operate from DC up to 300Hz (look at Analog Devices, Freescale, etc)
 and have a ratiometric or 0-5V output.
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 8
(4,247 Views)
The NI 9232 module has a AC Coupling Filter at 0.1Hz, and accelerometers designed for Wind Turbines also have a low frequency range.
Consider this accelerometer
https://www.ctconline.com/__500_mv_g_accelerometer___low_frequency.aspx
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
Message 3 of 8
(4,241 Views)
Hello Preston_Johnson
Is this an IEPE accelerometer????  I am asking because the NI9232 is only designed for IEPE sensors as you know.
Message 4 of 8
(4,229 Views)
Yes it is an IEPE sensor.
The 9232 works with IEPE sensors, as well as any other sensor where dynamic measurements are desired.  The 9232 has +/- 30V range, 4ma of IEPE (when IEPE is turned on), and options for AC coupling (0.1Hz) and DC coupling.  We use the module for IEPE accelerometers, mems accels (DC powered), proximity probes (output of demodulator), current probes, microphones, dynamic pressure, charge coupled accelerometers using an in-line IEPE to charge converter, and really any dynamic measurement whose sensor is +/- 30V range.
The input configuration options are IEPE with AC coupling, AC coupling, DC coupling.
Preston Johnson
cbt
512 431 2371
Message 5 of 8
(4,226 Views)
Preston_Johnson
I really appreciate your help and I will consider this sensor. Do they sale the connection cable with it? How do you connect this sensor to the NI9232 which is as you know screw terminal.
Regards
Message 6 of 8
(4,224 Views)
Yes - CTC sells cables as well.  You would want  one with bare leads to easily connect into the 9232 module screw terminal connector.
Preston
Preston Johnson
cbt
512 431 2371
Message 7 of 8
(4,213 Views)
Preston_Johnson
Thank you so much you helped me so much by your technical replies.  I appreciate your help.
Message 8 of 8
(4,211 Views)
