Abort Sub VI
    All,
      What I'm trying to do here is abort a sub vi that is running an event loop. The problem is the front panel locks up while the SubVI is running and I can't generate the abort event. Code is attached. Thanks for the help.
(3,613 Views)
In your Main vi, edit the event case for the Run value change, and uncheck the checkbox next to "lock front panel until the event case for this event completes".
- tbob
Inventor of the WORM Global
(3,603 Views)
In addition to tbob's suggestion it is generally not a goood practice to put any code inside an event structure which might take longer to execute than the minimum time between events. If you run the subVI in parallel to the main VI, the main can continue to respond to its own events.
If all you are trying to do is to stop the subVI from the main VI front panel, there are much easier ways than nested loops and event structures: Notifiers, queues, occurrences, action engines, global variables, ...
Lynn
(3,587 Views)
Hi Kenneth.Miller,
You can use Emergency VI Aborter
https://decibel.ni.com/content/docs/DOC-2309
Best regards
Van Phu
(3,102 Views)
vanphu:
You are about 4 years too late in your response.  Smiley Happy  Check the date stamp.  Kenneth Miller may not still be around to read your suggestion.
- tbob
(3,079 Views)
