ASK remote front panel
hai bro i try to remote panels with labview 8.0 professional with this information :
http://zone.ni.com/devzone/cda/tut/p/id/4791
http://zone.ni.com/devzone/cda/tut/p/id/3277
and it's done, for example i give it name test then i start the web server it's works well.
but when i try to connect again with remote panel connection manager and open the project (test)
the remote panel connection manager says that they can find it certainly i've save and open it with the same name and folder where i save the project.
can youm tell me why  i can't do that?
tanx before, sorry for bad english
(3,383 Views)
What do you do differently the second time from the first? Are you opening it up differently? Are you using an executable? It doesn't look like it from your description but if you are there is a link below that may help.
Use Remote Front Panels without LabVIEW Development System
Vince M
(3,350 Views)
NIce share tanx. i'll try it
(3,331 Views)
in step 2. Add your source code to the project. what it's mean... i don't get it please explain that tanx
(3,318 Views)
Add source code to the project is refering to your LabVIEW VIs if you see your LabVIEW VIs in the project window already then you don't need to add more code. If you do not see anything in the Project Explorer window under My Computer and above Dependancies then you will need to add your VIs.
Vince M
(3,304 Views)
