ASCII values
I am using the serial port of my computer to read data from device. This
works fine. However, I can not manage to convert the characters in their
ASCII code.
Does anybode know how to do this?
Thanks in advance.
Jan Jaap
(3,534 Views)
In article <7kkujs$2p5ea$1@reader3.wxs.nl>,
"Jan Jaap Krikke" wrote:
> Hello,
This
their
> ASCII code.
> Thanks in advance.
> Regards,
> Jan Jaap
use the "String to Byte Array"-function (can be found in
Numeric->Conversion) to get your string converted into an array of
bytes, which contains the corresponding ASCII values.
Hope that helps.
Bye,
Alexander
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,534 Views)
Alexander, thank you very much for your opinion about conversion of characters to your correspondent code ascii, it help me so much.
Sincerely,
Wilton Filho
(3,526 Views)
