AR drone UDP error
Hi
 i am trying to controll my ar drone vie the AR Drone add on.
I hvae recieved the following UDP error(in error out).
The block diagram on the picture seems to be the source of the error.
I have tried to solve this but frankly, i do not even properly understand what this error means.
Can someone help me with this?
Thanks in advance.
(900 Views)
So you show us a picture with most of the error info hidden, but that's okay.  We can use Help --> Explain Error... to figure this out:
Possible reason(s):
LabVIEW: (Hex 0x1) An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Command requires GPIB Controller to be Controller-In-Charge.
So what this tells us is that it doesn't like something that is unbundled from your cluster.  You'll have to figure out which one it is.
Bill
CLD
(Mid-Level minion.)
(892 Views)
