API's supported by Real-Time?
I am working with a third-party vendor to get a driver working in LabVIEW Real-Time 8.  Can anyone send me a comprehensive list of the supported API's so I can forward on?  I know that the LabVIEW Real-Time Operating System only supports a subset of the Win32 API's but I don't know which ones.  Thanks. - Jerald
(4,273 Views)
Hi Samm,
Attached is a pdf with a section entitled "Supported Win32 APIs".  I hope it helps you achieve your goal, and have a good 4th of July.
Brian K.
(4,252 Views)
For size reduction, LabVIEW Real-Time does not support all of the APIs listing from Ardence ETS.    To know what functionality is actually supported with a particular version of LabVIEW RT, NI provides a utility that will verify a DLL.
Kevin Johnson
Section Manager: LabVIEW Real-Time R&D
(3,965 Views)
And in case you use any of the newer CompactRIO/Fielpoint targets running VxWorks you can forget any win32 API support. Only standard C runtime library support is available there.
Rolf Kalbermatter
Message Edited by rolfk on 04-09-2008 08:17 PM
Rolf Kalbermatter  My Blog
(3,953 Views)
