Is it possible to have an AO repettitively triggered without using software to reset the trigger? In other words can I not have the thing in a loop, and still have the DAC updated with a trigger?
The problem I'm havinbg is I have to generate a waveform (at ~100k) once every 50 ms. I have a trigger to start it, but that needs to be in a loop to have it generate the waveform on any other trigger rather than the first. Any suggestions?
Thanks in advance.
