Hi John,
I think you need to transpose the data. If you are just displaying the data on the panel, you can use the 'Transpose 2D array' function to do so and if you are writing it to a file you can wire a boolean True constant to the 'Transpose?' input of the subvi.
Hope this helps,
Pravin
