AF-1501 on LabVIEW 2013
Hello, NI Community,
I want to use AF-1502 framegrabbers with a single-board RIO 9632 with LabVIEW 2013. But there is only a driver for AF-1501 and the latest version for LabVIEW 2011-2012.
What I do:
I open example for AF-1501 and try to compile the driver VI (of course, at first I created a new project for sbRIO, copied folders: Exampels, RT, Drivers). When I compile (with Xilinx 14.4)  my FPGA code I get the above window and will be in the same status for more than 2 hrs and still no progress and then appear the error.
Then I try to compile the driver with LabVIEW 2011. Everything has finished good.
So, my question:
What should I do to use driver (for 2012 version) and LabVIEW 2013? Is it possible? (It is necessary, because there is an additional Vision RIO in 2013 version).
(3,204 Views)
Hi Luvia,
Have you tried to contact movimed, who created the module? They may have more information on compatibility with newer versions of LabVIEW:
http://www.movimed.com/AF1502-framegrabber.htm
The phone number to contact them is at the bottom of the page.
Paolo F.
(3,142 Views)
