ADO Error: 0x80040E14
I want to interface LabVIEW2010 and Microsoft Access 2003 by using UDL technique.  I am using Microsoft Jet 4.0 OLE DB Provider for this interface. When I Run the sample program, its showing an error Error -2147217900 as follows:
(occurred at NI_Database_API.lvlib:Conn Execute.vi->NI_Database_API.lvlib:DB Tools Create Table.vi->NI_Database_API.lvlib:DB Tools Create Table If Not Exist.vi->NI_Database_API.lvlib:DB Tools Insert Data.vi->Untitled 1.vi)
Possible reason(s):
Exception occured in Microsoft JET Database Engine: Syntax error in field definition. in NI_Database_API.lvlib:Conn Execute.vi->NI_Database_API.lvlib:DB Tools Create Table.vi->NI_Database_API.lvlib:DB Tools Create Table If Not Exist.vi->NI_Database_API.lvlib:DB Tools Insert Data.vi->Untitled 1.vi
This error is not consistent, I mean it occurs most of the times, but few times it just disappears 🙂  I have searched a lot on the NI site but not getting any solution.  Please help me to solve this error.
Note: I have attached my sample VI named 'Untitled 1' .
(16,649 Views)
The problem is most likely in the naming of your table or field names.
You may be using a reserved word or need to use a delimiter to handle table or field names containing a space.
http://www.adopenstatic.com/faq/80040e14.asp
(16,638 Views)
may be your creating same table multiple time with same name . please try different table name during each run of Vi . it will work.
(13,327 Views)
Number 1: This is a 3 year old thread.
Number 2: That is really bad advice. Your application should not be creating tables on the fly at all.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(13,316 Views)
In my case, error 0x80040E14 was generated inside "DB Tools Select Data.vi".
What solved the error for me was adding brackets [ ] around the names of the columns. For example, I was getting the error when reading columns "Index" and "Date", but the error went away when reading [Index] and [Date].
The "table" input works with or without brackets, e.g. both "table_name" and "[table_name]" work.
(9,216 Views)
It is possible that you have spaces in the column names. Regardless, place brackets like this [field1], [field2], [field3] for the column names (meaning the array of strings that attaches to the "columns" terminal).  This should fix the issue.
(7,777 Views)
