A point from a graph
Hi.
Do you know how can i find a point from a XY graph?..I know the Y coordinate and I want to find the X coordinate. My point is 0.9347. With interpolate? Any ideas?
Message 1 of 9
(4,702 Views)
Hi
You can do that (but you should not have two or more equal values of Y in your graph.... or if you do, you can select which x to obtain).
The simplest way (I think) to do it is to find the 2 or 3 nearest points of Y, close to your selected value, then obtain the line or polynomial coefficients and calculate x.
N
Message 2 of 9
(4,675 Views)
Assuming the data is non-descending, you can use threshold array. If you represent your xy data as an array of points, it will be easiest.
Can you show us how the xy data is currently wired to the graph (complex, cluster of x and y arrays, array of xy points, etc.)
Message 3 of 9
(4,665 Views)
Accepted by RavensFan
Hi again
Depending upon the number of points you have to search and what resolution, a simple search (might be time consuming) can be used. See attached vi
Message 4 of 9
(4,665 Views)
Technically I have some mean numbers which correspond to kg number..First 5 values I know that they are for 1-5kg. For the last one I have just the mean number and I know is between 3 - 4 kg. That's why i want to find it from the graph.
Message 5 of 9
(4,630 Views)
Hi
Have you tried the VI that I attached ?
N
Message 6 of 9
(4,626 Views)
I have LabView 15. Smiley Embarassed
Message 7 of 9
(4,620 Views)
Nitad's VI in LV 15.
Message 8 of 9
(4,618 Views)
Nitad's post should be marked as the solution.  All I did was convert it for you.
Message 9 of 9
(4,593 Views)
