A plug and play driver convert error
Hello, I' m trying to convert  plug and play driver to be used in LabView. In one of previous topics where the drivers were the same it was succesfull, but I've getting an error.
http://forums.ni.com/t5/LabVIEW/Is-there-a-similar-labVIEW-driver-to-the-one-on-NI-website-for/m-p/8...
VXIPlug&Play Driver for 4395A:       http://www.home.agilent.com/agilent/software.jspx?ckey=2249830&lc=eng&cc=LV&nid=-11143.0.00&id=22498...
installed following the Agilent recomendations.
Converted using: LabVIEW 8.2  and LabVIEW Interference Generator for LabWindows/CVI Instrument Drivers 1.1
Error: During conversion everything goes well but at the end in Conversion report apers that none of VIs can not be created.
Is the problem in my old LabView version or somevere else?
Message 1 of 9
(4,340 Views)
Hi ku_ku,
To clarify, is your goal to use this plug and play driver in LabVIEW 8.2 or in another version?  Also, would it be possible for you to attach a larger image?  The current image is too small to read.
Best Regards,
Michael B.
Message 2 of 9
(4,293 Views)
Did you install Agilient IO Libraries?  They are kind of necessary to have to run the pnp driver.  Without them the vis won't be able to find the DLLs they need and won't build.
"Should be" isn't "Is" -Jay
Message 3 of 9
(4,289 Views)
Hi... no I'm not limited with 8.2 version  prefered is 8.5... but it can be newer version as well....
Message 4 of 9
(4,253 Views)
I've tried to use 8.6 version and the result looks better but still it do not generate usable VI's
all generated VI have errors like this:
How to fix the Function Library node???
In attachment I'm adding report that is generated during VI conversion
Message 5 of 9
(4,244 Views)
OK. One more time.  Install Agilient IO Libraries.
Message 6 of 9
(4,234 Views)
hi, I've done the following...
1. installed -> VXIPlug&Play Driver for 4395A:       http://www.home.agilent.com/agilent/software.jspx?ckey=2249830&lc=eng&cc=LV&nid=-11143.0.00&id=22498...
2. converted to VI's using Labview (unsuccessfully, VI's do not work)
3. what libraries should I install more???
I'm in
puzzlement....
Message 7 of 9
(4,221 Views)
Accepted by topic author ku_ku
follow the link.... install Agilient IO Libraries
Message 8 of 9
(4,219 Views)
Thank you very much!!! Absence of IO Libraries vas the problem.
Message 9 of 9
(4,191 Views)
