A dll reerenced to another dll
Hi everybody
I need your help please!
I want to call from labview 7.0 a dll vb.net which is referenced to a another dll activeX
When I try to call a dl vb.net referencé to another dll vb.net it works well.
(2,974 Views)
So it works well! What was the question?
Rolf Kalbermatter  My Blog
(2,953 Views)
Hey Guibs,
if your vb.net dll successfully called another dll, then it shows that your calling dll works well. I guess the convention used to call the ActiveX dll is quite different so you will have to see how to get it working (for example by calling the ActiveX dll from a "true" program and not a dll).
Rik.
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(2,946 Views)
Hi Éric and Rolfk , thank for your reply.
I dont use convention but node cobstructor to call my dll.net.
I have a motor that is controlled by a vb6 program. In this program I referenced to a dll named Axinterop.Actimultilib.
My aim is to recuperate this program into a new dll and call this new dll with labview .
This new dll when it is called by vb. Net it works well but not with labview 7.0
I think Axinterop.Actmultilub is a activeX and is not supported by labview .
I am trying to replace this Axinterop.Actmultilub by interop.Actmultilub
(2,940 Views)
(2,937 Views)
