A basic question about String -> array
Hi, all,
I have an input String ":CURV 12,72,75,74,76,74,75,77,77,72,72,75,78,72, .....", totally 500 numbers, how can I change this to a 1-D array?
I tried to use "scan from string", but how to set up 'format string'? thanks
TBird
Message 1 of 10
(5,227 Views)
Since you have so many numbers, you shouldn't use scan from string. Instead, use a while loop to detect and convert each number, and output the result using auto indexing.
You can also take the first part off the string and use spreadsheet string to array with a comma as the seperator and a 1D U16 array as the type.
___________________
Try to take over the world!
Message 2 of 10
(5,221 Views)
I assume that this is the data retruned from an instrument. If that is the case I would recommend the Instrument I/O Assistant Express VI in the Express palette. It helps you set up the communication (which you already have working) and the parsing (which is the part you are having trouble with. It is really easy to use and helps out with most intrument communication when you don't have a driver.
Good luck
Message 3 of 10
(5,213 Views)
You can try the attached
Randall Pursley
Message 4 of 10
(5,201 Views)
Randall, I tried your code but it only transferres the first data (12) to the array, do I need a loop something? Thanks.
Message 5 of 10
(5,179 Views)
Eliminate the :CURV from the format string (just have %d) and then delete the first element from the array.
Message 6 of 10
(5,163 Views)
Randall's solution works id you modify it slightly:
Message 7 of 10
(5,162 Views)
Hi:
Try this vi in attachment.
Message 8 of 10
(5,151 Views)
fahlers, you code works but it missed the first data, how come? Thank you.
Message 9 of 10
(5,145 Views)
As tst said in the first answer you got, remove the first part (:CURV) and then use Read From Spreadsheet.
Message 10 of 10
(5,130 Views)
