A add button
How can I create a add button for selected items (indicators, controls or etc) or a item group.
Example: i have a row and this row include " text control and indicator + numeric control and indicator + combo box etc " when I press add row button
a new row (same old) creating.
Thank You.
Message 1 of 10
(4,263 Views)
You could use an array of clusters to add multiple controls with the click of an add button.
Is this the sort of thing you need?
See attached.
Message 2 of 10
(4,258 Views)
Hi Phil_ Thanks for your interest. Your file for LV2013 please can u save file for LV2012.
Best Regards.
Message 3 of 10
(4,248 Views)
There you go:
Message 4 of 10
(4,237 Views)
in my rows not full indicators or controls
a row can have a control and indicator.
Message 5 of 10
(4,196 Views)
Then you need make your array a control.  For the items that you want to behave like indicators, you will need to disable them (and change the appearance if you want a grey background like an indicator instead of white like a control.)
Message 6 of 10
(4,183 Views)
Hi. I fixed my row now. But a need help again.
I cant use elements in my row.
How can i use this elements for my numeric process
row1 have string control-1, numeric control-1, etc. when i click add button
row2 have to  string control-2, numeric control-2, etc
and i must use this elements with a local variable.
Message 7 of 10
(4,142 Views)
To use the elements in a specific row, you will first need to index the array, then unbundle the cluster.
Like so:
(assuming am I understanding your problem correctly?)
Message 8 of 10
(4,132 Views)
Row1: string control-1, numeric control-1, string indicator-1, numeric indicator-1, etc-1.
Row2: string control-2, numeric control-2, string indicator-2, numeric indicator-2, etc-2.
____________________________
I will need example:
numeric control (or indicator)-1 x numeric control (or indicator)-2
numeric control (or indicator)-1 / numeric control (or indicator)-2
numeric control (or indicator)-1 + numeric control (or indicator)-2
numeric control (or indicator)-1 - numeric control (or indicator)-2
Message 9 of 10
(4,124 Views)
Surely you can work this one out for yourself....
Message 10 of 10
(4,116 Views)
