A Problem of "Reference"
Hi karivotski,
use controls from "classic" palette, they are easier to customize.
Then use the brush tool to color them as needed!
Message 11 of 16
(1,107 Views)
Thank you !
Message 12 of 16
(1,105 Views)
Just an other question : My array have several buttons. I want to blink each buttons, so I have to place a LED behind each buttons in order to blink it as you told me. But it is a bit boring to do this ... so I though that I will do an array of LED, but If I do this, I will blink again ALL the LED as you told me ? Am I right ?
Thank you !
Message 13 of 16
(1,101 Views)
Hi karivotski,
you should use colorboxes instead of LED indicators so you can change their values!
(If you use LED indicators you can switch them between T/F to simulate blinking, with colorboxes you could even fade colors…)
Message 14 of 16
(1,099 Views)
@karivotski wrote:
I can't open your file ... I have the 2014 version of LabVIEW ... Could you please send me your file by using this version ?
Sure, I thought I linked to the thread instead of the attachment. Here is the thread.  And attached is the 2014 version.
Message 15 of 16
(1,094 Views)
At the beginning , I was working on color box but I can't change the visibility of the color box ... and I don't understand how the "transparent " color works ... because when I put the transparant color to the color box, (a big T appears) but it is not transparent and I can't see my button behind ... Where as with the Led indicator I can see my button if i change the visibility of the LED indicator.
Suppose I use a color Box could I change the value of each button contained into an array without modifying the values/transparency of the other buttons ?
Thank you !
Message 16 of 16
(1,094 Views)
