9265 programming
Hi Jan,
Can you give me an update, are you able to output a desired current?
Kind Regards,
Joris Donders
EMEIA GTM Lead for Semiconductor
www.ni.com/semiconductor
Message 11 of 13
(1,586 Views)
OK, here is the update (also for Basset Hound)
I ran my own vi again (since the example didn't work either) and included the 'FPGA status report'.  It gave the same result as in the LV example.  I don't know the nbr of the error as I can't wire an error handler to my nodes.  The example uses some other kind of FPGA I/O but I can't find those.  I added my vi's in annex.
Meanwhile I'll try to (re)verify my cRio and see if everyting is wired correctly.  I can use all other components (9211, 9203 and 9481) without any problem (???).  I'm also going to try to put the 9265 in another slot and see if that helps.
Jan
Message 12 of 13
(1,576 Views)
OK guys, the beer is on me ! :))
When I moved my system last week, I forgot to reconnect the power supply to the 9265 ... .  That's why I had a reading last week and now it didn't.  It's working fine now.
Sorry for the trouble
Jan
Message 13 of 13
(1,529 Views)
