9233 record
hi I'm new in labview and other programmation languages I use a NI-9233 to read data of 4 accelerometers at the same time I use example for reading the four accelerometers at the same time but when I want to record signals in .wav file labview says me that it can save only one signal. How can I do ? And I want to read at new the signal (precedement saved in the .wav file) i find an example but i can only listen it and no see in graphs (sorry if the english is not very good 😛 I hope you will understand all ^^) thanks for help
(3,056 Views)
Hello.
Can you please tell us which example you use to try to save your waveforms in a .wav file?
Concerning your second question, there's an example in LabVIEW examples wich allows you to see your .wav file in a waveform.This example is untitled:Read Sound File to Chart.
Thank you.
(3,023 Views)
Hello
i find my mistake that i wanted to record 4 ways in a same .wav file while that can record only two (mono and stereo)
thanks for your help
(3,005 Views)
