9219 is slow reading RTDs
When I read voltage, current, or themocouples in a NI 9219 module (in high speed mode with USB carrier 9162), it returns in less than 20 milliseconds. This is good for my application.
When I try to read RTDs, the module takes 500 milliseconds. I don't know what I am doing wrong. Attached is a test program that demonstrates this problem.
Any suggestions (well ... almost any suggestions 🙂 will be appreciated.    Thank you!
(3,147 Views)
Dave,
   This is curious. Perhaps there some overhead associated with setting up the measurement. Have you tried running the acquisition in a loop and seeing how the time response is then? Have you made any other progress on this issue?
Regards from Austin,
Ben J.
(3,098 Views)
Hi Ben,
Thanks for your response.
It looks like a problem with the RTD sensor caused the issue. I discoved this while running the test you suggested. Thank you very much!
Dave
(3,077 Views)
