9211A USB cjc
Hello comunity
I am trying to acquire the voltage from a special thermocouple using the USB 9211A module. In Max I see the cjc channel but when I build a vi I can't. I can see though the value of the cjc channel (ina property node) if i switch the channel from voltage measurement to temperature measurement. In this case it is 25 and not a binary or voltage. I would be happy to translate thet value in voltage but it is very rough. I was expecting at least a few commas.
hence the questions: why I can see a fifth chanel in Max (seems to show a voltage value) but in LV I only see four? how to read this channel? Is there any zeroing like in the cRIO case?
Yannis
(2,894 Views)
Hi Yannis,
To read the CJC channel on your USB 9211A in LabVIEW, create a control or constant for the channel name, right click the control/constant and select "I/O Name Filtering...". Check the "Internal channels" checkbox and click OK. This will allow you to see all channels for the device including the CJC channel.
You can also wire a string constant or control into the DAQmx Create Channel block to choose the channel, e.g. "Dev1/_cjtemp".
More information on reading the CJC channel can be found in the following KnowledgeBase article:
http://digital.ni.com/public.nsf/allkb/862567530005F09C8625670A00664B6C?OpenDocument
I hope this is of use to you.
Tom
Applications Engineering, NI UK
Tom
(2,877 Views)
