9 axis wt901 imu sensor to be interfaced with labview using i2c
i am trying to interface a wt901 sensor with  crio using i2c implementation with daq card NI 9403, the api i have used is the one we can get from vipm i will link the snapshot of the vi below the problem im having is that when i try to select the ports for my scl and sda lines they show that no I/O is available will link that below as well. how can i troubleshoot this. im quite new to labview so please bear with me.
(2,237 Views)
Regarding your question on the interphase, you can also refer to the links below that has a similar questions with yours.
1. Using I2C or SPI communication with cRIO and NI 9403 Module and Scan Engine - NI Community
2. I2C, SPI, and JTAG Communication with NI Digital I/O Devices - National Instruments
Understanding the I2C Two Wire Bus Interface with NI LabVIEW - NI
I believe there would be some examples which you can refer in link 2.
Best Regards.
(2,184 Views)
