8641R RSSI I/O
I'm under Analog Input, and I see a IO called "ADC_0_Port_A_RSSI." Where can I find information about this among other IO names? I looked under specifications and help files, and I don't any of these things mentioned.
Thank you
(3,582 Views)
Hi d1sturbanc3,
I am a little confused to what devide you are using. Can you provide a little more detail.
thanks.
FLash
(3,570 Views)
I am using PXIe-5641R on a PXIe chassis. Oops. I hit the 8 instead of the 5.
(3,568 Views)
Hi d1sturbanc3,
Ok thank you, that makes a little more sense. I assume that the "ADC_0_Port_A_RSSI" is from the I/O list in your project. Correct?
FLash
(3,549 Views)
yes that's correct
(3,532 Views)
d1sturbanc3,
The 5641R is supported entirely on the IF RIO board I would suggest you ask there.
Sincerely,
Jason Daming
http://www.ni.com/support
(3,512 Views)
