I just started working with the 8451. In the connector diagram in the user manual, pin 32 is indicated as a Ground. However, I measure it against pin 1, 8, 25 and 26 where these are also indicated as Ground. Pin 32 appears to be isloated on my 8451. In addition, I do not measure +5V if I probe pin 31 and use pin 32 as a Ground. I do see +5V if I use these other pin as Ground.
Is my 8451 correct or is the manual wrong?
Thanks.
New LV User
(3,042 Views)
Hello New LV User,
See the following post which discusses the same topic.
Angela
(3,024 Views)
Thank you for your help. After I tightened the screw it is working fine now. Pin 32 is acting as a Ground.
New LV user
(3,012 Views)
