8116a continuos operation
Hi Everybody,
I am using Labview 7.1, I downloaded an older driverfor HP 8116a function generator.  Is there a way to program 8116a so that it operates continuously. It is possible to do this manually. I juct could not do it with labview. It only produces a pulse. If I use a while loop, it produces series of pulses.
Thank you very much for help in advance.
Birol Ozturk
Oklahoma State University
(3,041 Views)
Are you running the HP 8116A Getting Started VI? What are your settings? If I remember correctly, you only have to set the trigger mode to normal for continuous output.
(3,039 Views)
Thank you Dennis,
Looks like I changed some setting accidentaly. It worked now!
(3,033 Views)
