8.5 crashes when load vi
Labview 8.5 crashes with no error messages...just exits...while loading the attached VI. Going to cause me a lot of grief if I can't recover it.
TIA,
Les
Message 1 of 8
(3,496 Views)
I can get it to open but you have not included any of the subVIs.
Frankly, if it's corrupt, you might be better off rewriting it. It does not make any sense and it is, imho, very poorly written. I have no idea why you think you need all of the separate event structures, nor why you have a lot front panel controls you poll instead of using an event, or why you would have constants wired to the while loop's termination terminals.
Rewritten, you can make it fit on one screen and then you can actually have a chance of maintaining it.
Message 2 of 8
(3,489 Views)
I can open it too, but I strongly recommend that you rewrite this from scratch, because it is not maintainable code.
  • Currently, the diagram fills several hundred screens with mostly empty space and duplicate code.
  • There are over a dozen event structures running in parallel!!! One is enough, just add more cases!
  • Most (All!) data manipulation in done via locals and value properties.
  • There are infinite loops (hardwired to run forever!) within infinite loops, deadlocking all dataflow.
  • lots of duplicate code.
  • Layers and layers of deeply stacked sequences.
Who wrote all this? 😮
Message 3 of 8
(3,474 Views)
LMAO!...At least you can load it.....OK, now that we have established that I don't have a CLUE what I'm doing.....( BTW the program actually works )...where is there an error log I can look at, or how can I create one?
TIA
Message 4 of 8
(3,468 Views)
Accepted by topic author mastaflash
What I did not mention before is that it loads fine in 8.6. Just tried to load it with 8.5 and it crashed. I then opened it in 8.6 and did a save for previous. 8.5 was then able to open it. Try the attached.
Message 5 of 8
(3,458 Views)
Outstanding! Thanks.....
....If I ever get the time, I will rewrite it...but for now it does what is supposed to, and has for months...
Les
Message 6 of 8
(3,451 Views)
(Just another data point: It also opens fine in 8.5.1, must be a small bug in 8.5 somewhere)
Message 7 of 8
(3,446 Views)
Thanks, even better. :smileyhappy:
Message 8 of 8
(3,441 Views)
