6503 Change Notification
I Need to program a 6503 DAQ board with port A as a pattern matcher. It has to generate an event when bit 0=1. How do I program it without polling the line i LabVIEW.
(3,191 Views)
The NI-6503 does not support hardware change detection. The only way to do it is by polling the line.
Regards
Karsten
(3,191 Views)
Karsten,
what's the pattern match feature? Can't I use it as a change notification occurence?
Thx Ruud.
(3,191 Views)
There is no way that you can setup a program with this card which does pattern matching or change detection without polling the lines. To do so you will need a board which supports the change detection feature.
Best Regards,
RikP
Application Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(3,191 Views)
