6250 PCI Multiple PORT write
How to i write multiple port using DAQmx in PCI 6250. i want to write all 96 channels( 3 port (32bit)) at a time.
(2,702 Views)
hello,
I think that you're confusing something. Cause this board has 24 DIO. So you can only have 24 configured has output. So, if you wanna write channels, you can only write on those.
If you want an example to write these 24 digital output, you only have to search labview examples. Try it. It's simple.
If this is not the issue. Rephrase the question.
Software developer
www.mcm-electronics.com
PORTUGAL
(2,698 Views)
im sorry it was 6590 PCI and yes i tried using the exampla and i found how to do it
thanks for ur timly reply
(2,685 Views)
