6011 port error in labview (2010) while using a sit
i want to transfer my signal from MATLAB (2010a) to LABVIEW 2010 using simulation interface toolkit, during transfering my signal i am facing a problem "unable to connect to the SIT server in the simulation environment"
error window is attached with a question.
Message 1 of 19
(4,779 Views)
Have you confirmed that the SIT Server is running and configured for that port? You should see in the MATLAB® Command Window:
Starting the SIT Server on port 6011
SIT Server started
Additionally, can you confirm that any firewalls and anitviruses are temporarily disabled?
Bryan
Message 2 of 19
(4,714 Views)
yes i have selected a port 6011 and all the firewalls and antiviruses were disabled.
Message 3 of 19
(4,688 Views)
Toqeer,
When you run the command NISITServer('start',6011) do you see any error messages?
Bryan
Message 4 of 19
(4,662 Views)
Thanks for your reply
no there's no error
Message 5 of 19
(4,655 Views)
Toqeer,
Can you attach your LabVIEW code?
Bryan
Message 6 of 19
(4,609 Views)
As my Simulation toolkit is still not working but when i first run NISITServer it shows this message ( attached in figure 1) when i run it second time NISITserver after doing some work on matlab or even when i make my mdl file (MATLAB) connection on labview through SIT connection and runs NISITServer it shows this message both times (attached in figure 2).
What does these means? and how can i resolve these errors??
I am trying an example given in a http://www.ni.com/white-paper/3057/en/ ..
Message 7 of 19
(4,590 Views)
hi
i also facing same issue please answer this and required solution ?
Message 8 of 19
(4,486 Views)
Are you using a supported compiler? A compiler compatibility chart can be found on this KnowledgeBase.
Message 9 of 19
(4,440 Views)
Thanks for reply,
yes i am using compatible compiler as mentioned in a chart.
But still facing a same problem, error (56 and 66).
can you please tell me the importance of SDK while using SIT?? is it compatibilty also matters?
Message 10 of 19
(4,414 Views)
