5600 + 5640R - FM Demodulate
I want to use the ni5600 Downconverter & the ni5640R FPGA to demodulate an FM signal centered at 433MHz.
Any examples that control both these modules together?
Thank you.
Ajay
(2,584 Views)
I would check out the IP Net: http://zone.ni.com/devzone/cda/tut/p/id/4799#toc3 it's repository of examples and FPGA IP, there is a RF and Communications section. As you work through a solution and get problems or have questions, I would suggest to post them as well.
Anna K.
(2,524 Views)
