5401 in arbitrary mode
Hi at all!
I tried to configure my PXI 5401 as a simple arbitrary generator using FGEN drivers. But until now I already fail while configuring the device as arbitrary using the niFgen Configure Output Mode. vi 😞 I'm getting an error -1074135039: the 5401 doesn't support output modes NIFGEN_VAL_OUTPUT_ARB
If this fails how else is it possible to use 5401 as arbitray?
Regards
Oli
(2,821 Views)
Sorry, couldn't see the wood for trees. Didn't realize that an arb waveform is called user Wfm with the 5401....
But: does anybody know if it it possible nevertheless to define a marker signal on such a waveform?
Oli
(2,820 Views)
The 5401 doesn't support markers. This feature is supported by the newer boards like the 5411, 5421, 5431 and 5441. Maybe you could use the SYNC output but it only generates a meaningful signal if you generate a sine signal (please refer to the NI Signal Generators Help).
Jochen Klier
National Instruments Germany
(2,808 Views)
