4 analog signal to read
Hai guyz,
How do I configure my DAQmx or coding so that it would be able to  read four signal at once. Im trying to read 4 analog voltage signal from my sensor. I appreciate any help.
Newbie92
Message 1 of 13
(3,902 Views)
Don't make it so complicated! All that you needed is a single task with one Create Channel, Timing, and DAQmx Read. The channels can be selected by clicking on Browse or entering Dev1/ai0:3. You then change the DAQmx Read to N channels.
Message 2 of 13
(3,891 Views)
Hai Dennis_Knutson,
Could you show me the code example for it?
Newbie92
Message 3 of 13
(3,884 Views)
You've got the code. You just need to delete the extra tasks you have. Look at the examples as well.
Message 4 of 13
(3,862 Views)
Hai Dennis_Knutson,
I tried what you recommended but I don't know how to connect this new Read task to the multiple formula block. One more thing, I forgot to mention that I want it to take the reading simultaneously from the 4 different sensors I've placed. Can that be done as well in the method you recommended above?
Newbie92
Message 5 of 13
(3,855 Views)
Could you be kind to show me how it is done using the code I've attached?
Message 6 of 13
(3,843 Views)
Anyone?
Message 7 of 13
(3,812 Views)
Hi Newbie,
Dennis told you what to do. Have you even tried to change your code?
When you need examples: open the example finder! Look for DAQmx example VIs showing how to handle more than one channel…
Message 8 of 13
(3,790 Views)
Hi GerdW,
I did try to find example in the Find Example in help but can't find one. Maybe I missed them. If you have one that is similar I'll be glad to study it. The attachment I sent was the unedited one. Here I'll show you what I tried. I got stuck on how to set the Reader task. Sorry for posting the wrong code.
Regads,
Newbie92
Message 9 of 13
(3,775 Views)
Here's a quick example.
Message 10 of 13
(3,746 Views)
