4 AXIS MOVE VI
I want to blend the motion of 4 axis, the axis have to read the target position from a .txt file. I have initialized two vector spaces one has three axis and the other has one axis only. When I run the VI I get an error message which says illegal time error at blend function. How Do I remove this error. I am sending the VI as an attachment, Please download the VI and help me fix the error.
(3,084 Views)
I am also working on similar case and would like to know if anyone has solved the problem.
(2,975 Views)
Hi Tommi,
This issue has been addressed on two other discussion forums (which follow each other in sequential order):
  1. Blending 4+ axis using flex motion 6C card and software
  2. 4 AXIS MOVE VI
Hope this helps,
Irene Chow
(2,955 Views)
