3d solid rotation
Does anyone have experience or an example VI of doing solid rotation with a 3D graph? I can use the ViewLatitude and ViewLogitude properties to do a solid rotation, but I'd like to have the ability to rotate with the mouse, except not show individual points disconnected but rather a solid line like graphed.
Also, I am trying to have each plot be one color, not differ in color according to its intensity (see attached VI). How do I do this?
Michael
(3,180 Views)
If you want to change a lot about the 3D graph, perhaps you should have a look at the 3d picture control. It will be some work to get started, but you can do everything you want with it. However, I don't think drawing text is supported, so drawing scales will be impossible.
Wiebe.
(3,168 Views)
