3d simulator
I’m a complete newbie to LabView; I’ve no idea of its capabilities but was recommended to use it for a part of a project I’m working on.
Basically I’m working on a circuit with 12 pin outputs that will switch different lights a set of traffic lights, What I want to do is develop a simulator, I need to know is it possible to use a data acquisition card with LabView and somehow develop a 3D model of the lights in LabView to light in different ways according the 12 outputs of the hardware I’ve built, outputs form the circuit would be logic hi & lo 0 - +5 volts.
Any help or even tips on where to look up this info would be great.
Kevin
(3,743 Views)
Hi Kevin
What you're looking to do sounds readily achievable with LabView.
You'll need a digital I/O card to sense the outputs from your hardware.
Look here for NI products
As your a newbie it'll be worth spending time going through a few examples and tutorials to get up to speed with what LabView can offer. You can produce a GUI in minutes using built in controls and indicators - see attached example.
If you get stuck, the forum is full of friendly folk to help out. 🙂
Good luck
Neil
(3,733 Views)
Thanks Neil,
I have a link with the data card I was thinking of using;
http://www.measurementcomputing.com/cbicatalog/cbiproduct_new.asp?dept_id=367&pf_id=1665
My budget is quiet small and I have to get a portable USB card would this suffice do you think?
thanks for any help
Kevin
Message Edited by KevinBolger on 03-01-2005 09:47 AM
(3,728 Views)
Kevin
Yes it looks pretty good, very reasonable price.
I guess you're only interested in the DIO capability, but the extra I/O may come in handy.
You get LabView Drivers and VIs to get you up and running. Ideal.
I know NI do the USB6009 which I think is similar. Don't know how the price compares.
Neil
(3,720 Views)
You can get the USB-6008 plus a student edition of LabVIEW for the same price.
(3,693 Views)
just paid for it this morning but thanks for the advice, looks pretty good
(3,685 Views)
