3d properties
Is there a way in a 3D graph to select intensity colors?
(3,272 Views)
There are two property nodes that must be used in parallel : the colormap colors and the colormap values.
You just have to affect a defined color to a given z (intensity) value. See the attached vi.
You can use different color mapping scheme with different plots on the same 3D graph.
Chilly Charly    (aka CC)
(3,265 Views)
Gracias! Chilly charly.
I had figured out a different way to do it but yours is best!
(3,256 Views)
