3d plot axis change font: is there any trick?
Another excellent question!  I think, if I had to do this, what I'd do would be to explore whether another program (Matlab and Sigmaplot come to mind) can create 3D plots (axes only) with the kind of labels (with symbols) that you want.  Scale the (empty) axes, rotate them, then you may be able to "cut and paste" the graphic elements onto your similarly-saved LabVIEW plot.  Yes, it is a fair amount of work, but (you are probably too young to) remember the old days, when you brought a list of points to a graphic artist and said "Draw this for me", it took weeks and was very expensive.  Now it still takes time, but much less, changes are easy to make, and you can "do it yourself".
Message 11 of 11
(766 Views)
