3d picture control wrl file
dear sir,
Anyone have an example using the 3d picture control VIs -- esp something reading a WRL resource. How do i change jpeg to wrl file.
Thanks and Regards
Jayanthi K
(6,536 Views)
Hi Jayanthi-
There's a simple example in this thread: Editing a .wrl object (see 'WRL.zip' attachment)
And if you want to learn more about using the 3D picture control with VRML, the following help files are great:
Using the 3D Picture Control
Hope this helps!
Drew Pierce | District Manager, Central Texas | National Instruments
(6,519 Views)
dear sir,
             Thank you very much for your help.
How do i generate wrl file.I developed my required picture using inventor then i convert it into jpeg file.
I download okino computer graphics software from google ,then using this software i export vrml(.wrl) file.But when i run my program no picture in 3d picture.
   I did not get anything in the output.
What is the problem,Pls suggest me.
Is there any software to creat a wrl file
Thanks and regards
Jayanthi.k
(6,513 Views)
Hi Jayanthi-
What are you ultimately trying to do? If you're trying to display a jpeg source file in LabVIEW, why are you converting it to VRML format first? LabVIEW can handle jpeg's even easier than VRML. And if you're already using "okino computer graphics software" to export a VRML file, why do you need "software to creat a wrl file"?
Please reply with clarification of what exactly you're starting with and what you want in the end, and hopefully I'll be able to offer suggestions as to the best way to implement it without making unnecessary conversions. Thanks!
(6,498 Views)
Dear sir,
              Actually  First I tried in Jpeg file,but in labview 8.2 when we are importing a jpeg we can use it as a texture only,so we should generate one object;so my total shape of the importing picture was changed.This is my problem,sothat i tried with wrl file,but that was not work ie no output in the picture output.
           Is it possible in jpeg , shall we use jpeg as a object with out texture,what can i do.
Pls suggest me
Thanks and Regards
Jayanthi.k
(6,460 Views)
