3d object control
My application is to import 3D VRML file in LV 8.5 I tried to load
a .wrl file using load vrml function but i could not see anything in
picture control.3d file which i was trying to load is of size 15 MB.
(3,151 Views)
Hi divya,
Can you post your code.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,148 Views)
here is the vi & 3D file
(3,142 Views)
