3d intensity model
Need to illustrate the condition of a pipe section as a 3d model where the condition of different parts of the pipe is indicated using color...Does anybody know of a solution for this for LabVIEW, e.g. an ActiveX control?
(2,945 Views)
Assuming that you have LV6, a solution is to use the Picture Control (it gives you the maximum flexibility). Also, you may consider Intensity Graph and 3D graphs (it depends on how you want to picture the information)
Hope this helps
(2,945 Views)
