3d graph and reverse iteration
Message 11 of 14
(726 Views)
hi evan,
your vi sure works. but i didnt really understand the boolean logic you used. could you please shed some light on it? i have also included the another graph in my vi showing the path this takes but it doest look like the right path.
Message 12 of 14
(707 Views)
As far as the difference between the two VIs I am not sure which works correctly for your application.  If you rotate our 2 graphs around you will notice that thet are taking different paths.  When mine hits the end of an x,y plan it simply increases z by 1 and reverses the x,y scan.  yours looks like it always starts the x,y scan at the opposite x.  So yours finishes the z=0 scan at x,y of (9,15), however it starts the z=1 scan at (0,15)
All my boolean logic does is decide whether I am counting up or down.  The 2 booleans are for whether I am counting up in x or in y.  So for z=0 the y boolean is true or count up.  In the mean time the x boolean switches every time I increase y.  So for y=0 its true and therefore I scan up in x.  However after that 1 line I toggle the boolean. now I know to count down in x.  So at y=1 I count down in x.  I continue this toggling for the entire plan.  Now when I reach the end of the scan I toggle the y boolean and the x boolean got toggled as well.
So for the last scan I was increasing y and x.  I just toggles the 2 so i will now count down on x and y.  Therefore I follow the exact same path backwards.
Let me know if this clears it up any.
Message 13 of 14
(700 Views)
hi evan,
your vi is the one which works correctly. that is how it should function!! thanks for all the advice. although i am just wondering can this boolean logic be converted to the old odd even logic? using boolean logic in my vi is quite troublesome. i mean the actual vi where this 3d scanning has to be implemented.!
Message 14 of 14
(689 Views)
