3d curve
hallo, i have a simple question.
i want to draw 3DCurve, which plots Sinuswave(y-axe), time(x-axe), and position(z-axe).
i have a simple example, that i didn't succeed.
can anybody help me?
(3,291 Views)
Hi, try this.
I hope it will answer to your question.
Bye
CLD - Labview Certified Developer
(3,279 Views)
Sorry I am trying to attach the file with no success....
(3,259 Views)
thanks for your reply
but that's not what i'm trying to do.
first of all it must be continuerly becaus i want to plot one of output,
second the time axes must be shown.
for example : 3D is time-output-position.
in my VI i cannot see the Curve. that's my question. Why? i see onyl a point..
thanks...
(3,254 Views)
You see only one point because you only generate one point. Creating an array from a scalar just makes an array of lenght=one.
You could built your arrays in shift registers (But make sure the array does not grow forever or you'll run into memory issues).
Attached is a very simple demo that builds three arrays. (1) i=time, sin(f(i)), position (from a control) and plots it in 3D. See if this can point you in the right direction.
(3,248 Views)
thank you very much,
wenn i want to plot two sinus curve with different positions or more than two, must i use 3D parametric surface?
is it right?
thanks
(3,231 Views)
