3d array to spreadsheet string
I need a spreadsheet string eliminating all rows [x, 0, 0].
Message 1 of 11
(5,601 Views)
Hi lesterino,
you can use the vi called Match Pattern to search the pattern you want to eliminate from the string and then use the concatenate string to concatenate the output of the match pattern before string and after string.
Hope to have understood what was your problem, but don't hesitate to contact me if you need any further help.
Bye.
Message 2 of 11
(5,542 Views)
Try changing it into a 2D array instead.
Message 3 of 11
(5,524 Views)
Very interesting, simple, Thanks!
I ask you another question, how can I put a null row between each loops? The goal is to obtain a carriage return between the spreadsheet string loop values:
29.171098,-7.003361,0.000000
29.630650,-4.693034,0.000000
29.907520,-2.353773,0.000000
30.000000,-0.000000,0.000000
78.296261,0.000000,72.011625
78.054900,3.321259,72.011625
77.332304,6.622042,72.011625
76.132929,9.881998,72.011625
Message 4 of 11
(5,503 Views)
Any solution?
thanks
Message 5 of 11
(5,468 Views)
Convert the numbers to strings inside of the loop.
After each 2-D array, concatenate another linefeed to the string.
Message 6 of 11
(5,459 Views)
I tried to do this, but it does not work.
can you help me?
thanks
Message 7 of 11
(5,433 Views)
Well, you have mentioned your output but what exactly is your input?
CLAD
Passionate for LabVIEW
Message 8 of 11
(5,427 Views)
as you can see in test3.vi Block Diagram:
Input is a 3D array,
output is a speadsheet string
Message 9 of 11
(5,418 Views)
Accepted by topic author Lesterino
Dear Lesterino,
you have three inputs on your "Concatenate Strings" between the shift registers. Change their order: the first input for the second input. Then the new data are pasted at the end of the data coming from the shift register. If you need a reverese order of the string (as it is now), you have to reorder the inputs on your "Concatenate Strings": 1. the line-feed 2. the new data string 3. the data from the shift register.
Cheers,
Message 10 of 11
(5,408 Views)
