Normally, you would translate an object, and then rotate it. However, if you use Set Translation and then Set Rotation it won't work. The object will be translated, but it will be rotated around it's own center, not the origin. If you use Set Translation, and then Rotate Object, The object will be rotated around the origin.
So, to rotate an object around a point, use Set Translate, and then Rotate Object.
I don't know if this is by design or if it's a bug. It's not very intuitive...
Wiebe.
