3D sensor map with vectors
I have been working with the 3D sensor map VI to create a colormap plot on an stl part. The part contains 7 different sensors that are capable of measuring 3D forces. What I actually need however, is to create a visualization of the 3D force vectors at each sensor site instead of a colormap. Each site would display the x,y and z force components with vector lengths proportional to force magnitude. Is this possible with the sensor map VI, or is there another method that may work?
(2,687 Views)
You might have some luck modifying this example code to fit your application.
https://decibel.ni.com/content/docs/DOC-7146
Eric L.
Applications Engineering Specialist
(2,664 Views)
